cancel
(Can't quite get the demenisons right) I findly came up the solution
N/A
A had problem not getting my measurements right
try every solution that posted did not work
centering Fan mounting holes around a larger hole (Fan)
I made square over the circle then used measuring distance on all 4 sides one night
came to me when brain storming to measure all 4 sides
see attach file
