Cannot get Original tutorial Drawing (Creating 2D Drawing with Solid Edge)
N/A
I cannot get the original tutotial drawing "sbddadr". I deleted the modified drawing "sbddadr1" but when I clicked on the original name of the drawing it has the modifications in the drawing per the tutorial. So, how do you get the original drawing? Do I have to re-download the software?
Re: Cannot get Original tutorial Drawing (Creating 2D Drawing with Solid Edge)
N/A
When you run the tutorial, does any draft file diaplay?
Do the steps of the tutorial display?
Rick B.
N/A
To: Rick B.,
You asked:
When you run the tutorial, does any draft file diaplay? Do the steps of the tutorial display?
On your first question: Yes, but it shows the modifications I have done.
On your second question: Yes, the tutorial steps do display.
N/A
I missed the part about opening the original file.
I thought you were saying that you could not see the file in general.
I'll send to you a copy of the original file to the email address you use to
log into the newsgroup.
Rick B.
