Cannot open File
N/A
I have recieved the attached file in an email. I copied this file to my customer
folder. After opening Solidedge, I tried to open the file. However, this file
did not appear in the customers folder. When I tried to open this file directly
from the email, Solidedge did open but I got an error message to the effect that
"the file .dft could not be found.
Any ideas?
Tim Reed
Tim Reed
1 REPLY
Re: Cannot open File
N/A
Hi Tim,
Copy the file on your computer somewhere. Then start Solid Edge.
My guess is that when you used File/Open, the file type was not *.dft.
Just click File/Open and make sure the file type at the bottom is either dft or
solid edge files or all files. You should see it.
Fred
>file
>that
>Any ideas?
>Tim Reed
Fred Menage
DesignFusion
Canada
