Reply
Change unit of measurments
need to know how to change measurement from metric to feet inches or english. also
is there a way to delite or erase a mistake thank you
Re: Change unit of measurments
Charles,
If you just want to change units for a single dimension you can click on it
with the Right Mouse Button and change its properties. The more general
answer to your question can be found by typing "dimension styles" in the
Help index.
You will have to be more specific on the mistake questions. You can select
and delete about anything. There is also Undo which can be accessed in the
Quick Access toolbar or using Ctrl+Z
David
"Charles Schmidt" wrote in message
news:4933fd7a$1@bbsnotes.ugs.com...
> english. also
