Reply
Changing the Layer of Multiple Elements
Dear all:
Is it possible to change the layer of multiple elements at the same time?
I have tried selecting multiple elements, then right clicking on the element to
bring up the properties window to change the layer, but during that process everything
is deselected but the particular element that I right clicked on.
This gets cumbersome when you have to change many elements.
Thank you in advance.
David Tsai
Re: Changing the Layer of Multiple Elements
Select all elements then on your Edgbar click the Move Elements button (see
attached image)
David
"David Tsai" wrote in message
news:478d35be$1@bbsnotes.ugs.com...
> Dear all:
> element to
> process everything
> David Tsai
David,
Thank you so much for the quick response! That worked out perfectly!
Best regards,
David Tsai
>attached image)
>David
>> Dear all:
>> element to
>> process everything
>> David Tsai
