Coordinate Dimension Glitch
Does anybody else use Coordinate Dimensions In Solid Edge ST9 Draft? If so, maybe you can give me some advise on how to manipulate the dimension after it is placed. We have already succumbed to the fact that in order to switch between sides of a part (top/bottom or left/right), one must hold the "ALT" key to start a new aligment set. However, when the dimensions are too close and I need to move one out of the way, I find it difficult to control slight ajustments. I grab the handle and move it in the direction I need to and it zooms off the page. This is very frustrating.
Re: Coordinate Dimension Glitch
Esteemed Contributor
What Maintenance Patch is applied?
Production: ST9 MP10
Testing: ST10 MP3
Thanks for the reminder. We only just installed ST9 about two months ago. I neglected to get the IT dept. to install the patches. Let me get on that and I will come back to this topic.
Betreff: Coordinate Dimension Glitch
Honored Contributor
Honored Contributor
Hi @Jake
maybe the viedo can help.
There is one point where I put in a jog to a dimension.
This is be done with selecting the dimension and then with ALT key pressed I click onto the dim line.
After that You easily can move this dimension.
(view in My Videos)
Wolfgang
Honored Contributor
Honored Contributor
Hi @Jake
and I just forgot to say that the options for that dimensions should be set properly.
Wolfgang
(view in My Videos)
Close, but not the issue. I have figured out how to up-load movies. so please watch this...
Honored Contributor
Honored Contributor
Hi @Jake
I think YOu must upload this drawing for a further investigation.
I have tested a similar situation here with different drafting standrads and can not repordue Your video with any of them.
I suppose a special setting or option in YOur draft file rsponsible for that behaviour.
Wolfgang
@Jake,
I recall seeing this unusual coordinate dimension "drifting" behaviour back in ST9 [on Windows 10] also, but I think it was fixed in an maintenance pack [could've just as easily been a coincidence, with a settings change]......and certainly have not seen it again with ST10.
