Reply
Custom Settings Location
I've created a custom dimensions style and would like to put it on another computer running Solid Edge 2D. Is there a file that I can just copy to a flash drive and put it on the second computer?
Ed
Re: Custom Settings Location
The Style is saved in the file you created it in. Typically this would be saved as a template file for all to use.
Save teh file in a known location... then on the other file edit the style.
Style, dimension style, orginizer and with organizer you can copy it over..
HTH
