Reply
DXF File does not import properly
Hi All,
I try to import a DXF file into Solid Edge and within the options dialog I can see the preview of the sheets in the file and they look pretty good.
After the real import it seems that something went wrong. The first sheet holds the right drawing but with a couple of too much lines that also seem to be too long.
The second page has a miniature version of the drawing in the lower left corner of the page.
Any hint what might go wrong?
Dietmar
Re: DXF File does not import properly
Hi All,
I found the trick.
It was importing mm instead of m. So it translated incorrectly.
Not it works perfect
Dietmar
