Reply
Diameter symbol too small
if I put dimensions on my sketch using the diameter symbol, I can see the diameter
symbol in the same size than the number behind it.
But if I print it, the diameter symbol is much smaller than the number. To show
you what I mean, I have attatched a pdf-file print-out.
Is it somehow possible to print the symbol with the same size than the numbers?
What settings will I have to change?
Greetings and thanks for answers
Dennis
Re: Diameter symbol too small
Dennis,
When I open your pff file and look at the dimensions, the diameter symbols
look to be the correct size. Am I missing something? Am I missing something?
Rick B.
Hi Rick,
thanks for your answer.
The symbol really is too small, but I found out it is an error of my pdf-creator
programme!
Sorry!
Dennis
