Dimensions
N/A
Hi again all.
Can anyone tell me how to have dimensions with no decimal places???
For example - 125 instead of 125.000
I have tried to change it in the properties part of the dimension to no avail.
Your help would be appreciated.
John
Re: Dimensions
N/A
John, when you place a dimension, there is a Round-Off menu on the ribbon
bar. Set it to a value of "1".
If you have already placed a number of dimensions and want all of them to be
absent the decimal places and assuming you have not changed them from the
default Round-Off, you can go to the Format menu and select Styles. Make
sure the style menu is set to Dimensions, select the dimension style to
change, and click the Modify button. On the Units tab, set the Round-Off
value to "1". All previously placed dimensions will now be updated to be
absent the decimal places.
http://grundey.blogspot.com
"John" wrote in message
news:48cc60cc$1@bbsnotes.ugs.com...
> Hi again all.
> avail.
> John
Re: Dimensions
N/A
Thanks for that. It took a while but have now got it rounded to where I want it.
>be
>Ken
>> Hi again all.
>> avail.
>> John
