Reply
HOW TO MAKE TEXT MOVE W/ DIM CHANGE
I have a group consisting of a dimensioned rectange and a text box inside located
about at the center. I want the text box to remain at this relative point when
I increase the rectangle's length. The text box identifies/distinguishes that rectangle
from others. However, when I change it's dimension, the box just stays in place.
Ron
Ronald W Latour
Re: HOW TO MAKE TEXT MOVE W/ DIM CHANGE
Ron,
Text boxes are not associative to any geometry. Place a callout connected to
one of the lines of the rectangle. Then turn off the leader of the callout.
The callout will remain connected to the line. If the line moves, so eill
the callout. This will not keep the callout in the center of the rectangle,
but will maintain the relative position to the line.
Rick B.
