Reply
Help !...
Dear All ...
I downloaded S2E Drafting from UGS this day and impossible to start...
- The download seems correct (WIZARD is used automatically for that)
- the installation too
- the SELicense is saved on a file SELicense.dat in the good repertory...
But No Button and no files SE2Ddraft.exe are found on my PC...
Thanks in advance to help me..
Best regards,
Marc
MARCP
Re: Help !...
Marc,
If you click on the Start buttom in the bottom left corner of the window, do
you see a program entry for Solid Edge 2D Drafting. Also if you pull out All
Programs from the Start menu, you should see a program Group for Solid Edge
2D Drafting. Do you see these?
Rick B.
