Reply
How can I create a detail view?
In my sketch I need a detail view with a scale bigger than 1:1. How can I add this
detail few on my sheet? If I press the "detail view" button and click on the detail
I want to scale up, nothing happens. I have retried it several times - with no success.
Maybe somebody cann tell me how it works. Or is this function supported by the free
2d version in the first place?
Greetings and thanks for answers
Dennis
Re: How can I create a detail view?
Dennis,
The Detail View command only works on Drawing views (3D or 2D).
Workflow that you will need to use is:
Create your geometry on the 2D Model tab (turn on by going to View menu).
On the Working Sheet, click the 2D Model View command (which will take you
back to the 2D Model Sheet to select a view) and define the geometry area.
Place the view.
On the Working Sheet, you can now use the Detail View command on the view
you placed.
"Dennis" wrote in message
news:454c8122$1@bbsnotes.ugs.com...
> Hello,
> add this
> the detail
> with no success.
> the free
> Dennis
