Reply
How to enable driving dimensions
For some reason the driving/driven dimension button is inactive. I have tried other
files and even created new files. Once in a new file I draw a line then dimension
and the driving/driven button is inactive. I am unable to place a driving dimension,
any ideas?
Re: How to enable driving dimensions
Terry,
Make sure you have Maintain Relationships enabled. Click on Tools at the top
of the application window and make sure Maintain Relationships is checked.
Rick B.
"Ricky Black" wrote:
>Terry,
>Rick B.
Rick,
Thanks a bunch! I could not figure out why it works on one PC and not the other,
was not too obvious. I'm not sure... how it got turned off. I have uninstalled
SE2D several times, cleaned the registry and just about given up. So I guess it
is not turned on by default, wonder why I have not ran across this before. Anyway
many thanks!
Terry
Terry,
You are correct. Maintain realtionships is turned off by default.
Rick B.
