How to open the Offline file when Teamcenter Toggle is ON
Im trying to open the Ofline files (From Hard Disk) when the Teamcenter toggle is On (Online). But its givinng error..
And how to save the Online files to Hard Disk..? Other than Send to "Mail Recepient".
Rak
Re: How to open the Offline file when Teamcenter Toggle is ON
Community Manager
Rak,
You mention Teamcenter. Are you trying to run the Free 2D Drafting in a file managed workflow? Or are you simply trying to open Draft files unmanaged. Free 2D Drafting is NOT set up (licensed) to work with Managed workflows. You must use it in an unmanaged way.
Do you also use Solid Edge. You should be using Solid Edge 2D Drafting Maintenance version. Talk with your reseller about this.
Rick B.
Sir,
Thank you for the prompt reply..
I think my question is not lear.
I am a Design Engineer.. We only do 2D drawings.. Our work flow is as listed below,
  • Open the Solid Edge
  • Login
  • Open Template
  • Complete the 2D drawing.
  • Upload
  • Check In
So I am doing ONLINE work... In the middle if I open any Drawings drom my Hard Disc (D Drive or E Drive) I will get an error message.. Same is attached..
My question is.. Is it possible to open an Offline drawings when I am Online..
Esteemed Contributor
You can only open "unmanaged" documents when the SEEC is turned off.  With no files open, click the App button, click Manage, and toggle OFF the Teamcenter client (SEEC).
You cannot work "mixed mode".
Production: ST9 MP10
Testing: ST10 MP3
Hello Sir,
Yes.. I was looking for Mixed Mode only... Now I got it.. Thank you so much...
Rak
