Reply
IF YOU GET AN INVALID LICENSE DIALOG - READ THIS
If you get a dialog when you run 2D Drafting stating that your license must
be updated it may be caused by the system date being changed at some time.
The license checking that is built in will detect this and report that the
license is invalid.
On some machines changing the date back to the correct date will fix the
problem.
On other machines changing the date back to the correct may not fix the
problem.
