Reply
Import component drawing
I'm a new learner with a question.
If I draw an object, can it be imported to another drawing?
Example, draw a gear in drawing 1.
Draw a gearbox in drawing 2 with that gear as a component.
Is there a way to import the gear?
George
Re: Import component drawing
George,
You can place the gear, which is the first drawing, as a block in the second
drawing. you can actually place it multiple times as a block. Read help
about creating and using blocks.
Rick B.
