Reply
Import dwg. Output isn't the same as Autocad LT 2004
I want to import an autocad file format dwg but I don't obtain the same output in
SolidEdge 2d v19 as Autocad LT 2004.
I have tried to modify many configuration's option when open a dwg but I don't obtain
a good result.
Is there an optimal setup to work fine with a file created with Autocad LT 2004
Re: Import dwg. Output isn't the same as Autocad LT 2004
Alberto,
Can you elaborate on what differences you are seeing?
Rick B.
