Reply
Insert Sheet
I have Solide Edge 2D Drafting ST V100, I am trying to insert a new sheet in my drawing.
I have many tabs at the bottom and when I right click on one it give, the options
of Insert Sheet, Delete Sheet, & Rename Sheet... I have tried to insert a sheet
and also rename a sheet and nothing happens!!!! What do I need to do????
Re: Insert Sheet
Susan,
That's strange! I just tried it on one of my drawings that has 14 sheets and I had
a similar result to what you had. After you try inserting a sheet right click on
one of the sheet tabs and select "Reorder" and I'll bet you'll see your inserted
sheet as "sheet1" in the list even though it doesn't show up as a sheet tab along
with the other sheets. That's what happens for me.
Ed
>in my drawing.
>options
>sheet
