Insert symbols
N/A
When typing text in free2d, I wish to insert symbol for diameter (or any symbol). So far I have never succeeded.
Can you help?
Fred
Re: Insert symbols
PLM World Member Genius PLM World Member Genius
Hi Fred
Which tool are you using to type your text?
Try using the call out command the small red A with a leader inside the group annotation
Re: Insert symbols
N/A
Hi Fred,
I've encountered exactly the same problem. I found out that if you use the Windows Character Map (Home/Insert/CharacterMap) AND you choose the fontset "Symbol", you will be able to copy and paste any special character into a standard text field.
Fritz
