Reply
Installation only launches the help library
After installing the 2d free version of the software, whenever I went to run the
program the only thing I could access is the help file. No idea where the rest
of the product went, but if anyone has had this happen or knows whats going on it
would be good to know.
Re: Installation only launches the help library
Grant,
Do you know how to use the registry? If you do, go to
HKEY_CURRENT_USER-Software-Inigraphics Solutions-Solid Edge. Delete the
Version 19 entry under the Solid Edge. This will return Solid Edge to its
initial installed configuration. If you do not know much about the registry,
be careful modifying the registry. Deleting the wrong thing can be
destructive.
Rick B.
