Reply
Keyboard usage
I have only tested this very nice program for a couple of hours so I might have missed
something. I can't really find a way to use the keyboard effectively and have to
resort to the mouse for simple things like changing drawing tool.
Simple example:
To draw a line I would like to be able to press "Z" to activate Zoom tool, zoom
to desired section, "L" to activate Line tool, "M" to activate Move tool and drag
the line to another place.
In this way I feel that I get help from the keyboard and work faster, instead I
feel that I am almost forced to use the mouse for all actions. In customize I can
assign either a control key + desired key (CTRL+L) but that is not really convenient.
The best solution seems to be the function keys but there are only so many of them
and less mnemonic help than using normal keys.
Anyone have some solution for this?
Re: Keyboard usage
If anyone knows a way to pan around using keyboard, preferebly the arrow keys that
would be great.
Re: Keyboard usage
I'm a newbie and know nothing, but you could try this:
Try going to the Help section and search for "Customize Keyboard"
Also search for "default keyboard"
Sam
>have missed
>to
>Simple example:
>zoom
>drag
>I
>I can
>convenient.
>of them
Re: Keyboard usage
If you hold down the Shift and Ctrl keys and also press the right mouse
button (RMB) while dragging the mouse, you will Pan. You can also Zoom by
using Ctrl + RMB press & drag. Fit the view by Alt + RMB click. Window Area
by Alt + RMB press & drag.
http://grundey.blogspot.com
"Peter Norman" wrote in message
news:4751a9d6$1@bbsnotes.ugs.com...
> keys that
> would be great.
Re: Keyboard usage
Thank you, very useful (although a bit har to remember).
>Ken
>> keys that
>> would be great.
Re: Keyboard usage
If you use them much, they will become second nature. There are also
devices from 3Dconnexion.com that allow Panning/Zooming using your non-mouse
hand, but not sure if they will work with Free 2D since there are no API's
for it to connect to. Ricky may know whether they may work.
PellaKen
news:4755dda3$1@bbsnotes.ugs.com...
>>Area
>>Ken
>>> keys that
>>> would be great.
Re: Keyboard usage
I've not had any success with the 3DConnects Space Ball, I use that with ProE and
Inventor, but doesn't seem to work with SE22D Free.
In the end I took it apart because it had these really bright Blue LEDs on it. You
could turn them off in the options, but if the system went to sleep, it'd power
them back up again and blind me or give me a headache.
Why do companies use Blue LEDS? They are the worst invention ever!
-AS
>PellaKen
>by
>>>Area
>>>Ken
>>>> keys that
>>>> would be great.
www.continual-motion.com
Re: Keyboard usage
I have a LCD paneled alarm clock with a blue backlight. Sometimes it is too
intense and I have to turn it towards the wall.
PellaKen
"Andy Southern" wrote in message
news:475d19d9$1@bbsnotes.ugs.com...
> ProE and
> it. You
> power
> -AS
>>non-mouse
>>PellaKen
>>by
>>>>Area
>>>>Ken
>>>>> arrow
>>>>> keys that
>>>>> would be great.
