Layers
N/A
Hi
I am working on a drawing that has 12 layers and more coming.
Is there an easy way to turn off all the layers except the one I want to work on
and then turn them all on again.
Also
Can I change the colour of all the lines in one layer with an overall command instead
of changing each line individually?
Ceoff
Re: Layers
N/A
Geoff,
Right click on the layer that you want to work on.
Click on 'Show Only'.
This will make that layer the Active Layer and will hide all other layers.
Then right mouse click on the Layers collector.
Click on 'Show All Layers'.
This will turn on the display of all layers.
Rick B.
Re: Layers
N/A
Hi Ricky
Missed that one!
Many thanks
Geoff
"Ricky Black" wrote:
>Geoff,
>Regards,
>Rick B.
