Reply
Legend?
I need to create a legend on my sheet that indentifies pieces of my drawing. Such as existing walls, proposed walls, light fixtures, air exchange/returns etc... So far Im just laying out lines and adding text on my sheet, then I think I'll just take a view of the piece and scale it down small enough to fit next to the text in the legend. Is there a better way to do it? Possibly with tables? Any thoughts or ideas will be appreciated!!
Matt J.
Re: Legend?
Matt,
I would definitely take a look at tables for this.
You can create as many columns or rows as you need to fill in the data.
Rick B.
Re: Legend?
Matt,
I find it easier to produce drawing specifications as a table in MS word
where it is easy to make changes. Then use the usual MS Word copy and paste
routine to copy the completed Specification Table from Word to the Solidedge
drawing. The size of the table in the Solidedge drawing is easily adjusted
using the handles at the corners of the insert box.
I guess the routine is the same for V102, I am still using the earlier
version (V100?) and need to pluck up courage to update!
Sincerely,
Roger Hurrell
"madmattjones@roadrunner.com"
wrote in
message news:madmattjonesroadrunner.com.47uukz@noreply.bbsnotes.ugs.com...
> Thanks,
> Matt J.
> madmattjones@roadrunner.com's Profile:
> http://bbsnotes.ugs.com/vbulletin/member.php?userid=226359
> View this thread: http://bbsnotes.ugs.com/vbulletin/showthread.php?t=41722
