MAKING CUSTOM BACKGROUND SHEETS AVAILABLE GLOBABLY
N/A
I created a custom background sheet in a drawing that I would like to make available to any drawing that I'm working on just like a BLOCK. Can that be done without having to imbed the custom BG sheet into a template that is than used for all other drawings?
Ron
Re: MAKING CUSTOM BACKGROUND SHEETS AVAILABLE GLOBABLY
Community Manager
Ron,
If you want to make reuse of the background sheet, it must be in the template that you use to create new drawings.
Rick B.
N/A
Ricky, thanks. I decided to make a BLOCK of the background sheet overlay design and retrieve it to make BG sheets in different files. I had been doing this by overlaying the worksheet directly. But I was experimenting with BG sheets the other day and realized that it is easier to use them compared to my previous method.
Ron
