Reply
Making a custom information area
Instead of going by what Solid Edge creates in the bottom right, how can I
customize the fields and resize them?
Re: Making a custom information area
Another question is the "Revision History" at the top right of my A Wide
11x8.5 sheet will eventually get in the way. I used to draw it manually in
the bottom left. Can I move it there?
"Craig@Spectrum" wrote in message
news:4d88bd26$1@bbsnotes.ugs.com...
I guess you are talking about the sheet title block.
A default working sheet (Sheet1) does not directly contain the background
geometry.
This geometry is on a Background sheet.
Each working sheet (Sheet1) may or may not have a background sheet assigned.
Click on the View tab at the top.
Click on Background.
You will see the list of available background sheets at the bottom.
If you Right Mouse Click on the working sheet tab at the bottom,
you can click on Sheet Setup and see what background sheet is assigned to a
working sheet.
It is on the Background tab of the Sheet Setup dialog.
You can create as amny background sheets as you want.
Just assign the needed background as required.
Rick B.
