No Subject
N/A
John,
Attached is an example of what you can do with blocks. Draw the cutting
plane geometry as lines with a thicker symbology and different line pattern.
Create a block for the arrowhead that has the geometry and caption label.
When you place the block it will prompt for the label. Connect the block to
the end of the cutting plane geometry. Place a perpendicular constraint so
that the block remains perpendicular to the cutting plane geometry if it is
moved.
Rick B.
