Reply
No startup screen
I am not able to see any startup screen on my Solid Edge 2D Drafting V20. Any help?
Sriram
Re: No startup screen
Sriram,
Does the software run at all? Are you getting any error messages when you
the software is run?
Rick B.
No. The software does run. I am not able to see any startup screen even
after checking the check box under helpers tab in Options menu
"Ricky Black" wrote in message
news:477bb72c$1@bbsnotes.ugs.com...
> Sriram,
> Regards,
> Rick B.
Srikanth,
Is this a new installation that you are seeing the problem with or has it
worked before and you are now seeing this problem?
One requirement for Solid Edge is Internet Explorer 6.0 or higher. Do you
have IE 6.0 or higher?
Rick B.
