cancel
Problem with cyrilic in Solid Edge ST9 of Windows 10 Enterprise
I have a problem with solid edge files. When i write title and reopen this file the program could not read the title.  and show symbols instead letters. You can see at the atteched file. Can you help me.Is it from Solid or Windows and how can I decide this problem.
Thank you in advance.
Re: Problem with cyrilic in Solid Edge ST9 of Windows 10 Enterprise
I guess this may be related to non-Cyrillic fonts used in the title block for the problem callouts, or, possibly, language settings in Windows. Please check this In Language and regional settings, Advanced tab:Часы, язык и регион_2017-02-21_18-05-45.jpg
And make sure that language with Cyrillic is specified here.
Hi
We have the same issue.
When i reopen recently closed file/ assembly .asm or part  by me Its OK.
But when a collegue opens it ( another user in our network ) the titles are gone.
Can it be caused by  Insight ? We coudnt find any solution for this issue.
The parts and semi-assembly titles are gone each time we open a file.
And they have to be rewriten manualy on the parts,which is extra work. waste of time and resources
PLease help solving this isuue.
