Registration Problem
N/A
Hallo!
If I want to start the programm i always get the following massage:"The application was not registered correctly. Maybe it is neccessary to install it again."
I already installed it again but i still have the same problem. Who knows any solution?
Thanks in advance!
[langtitle=fr]Re: Registration Problem[/langtitle]
N/A
je ne sis pas à qui m'adresser pour les problèmes d'installation de solidedge2d je suis novice sur ce forum et ne sais pas comment ça marche si quelqu'un veut bien m'aider je l'en remercie d'avance ,mon adresse email vanderling@voo.be
N/A
What operating system are you running?
Make sure you have administrator privelages to install the software.
If you are running Vista or Windows 7, you must turn the UAC (User Account
Control) all the way down.
You can reset it after you finish the installation.
Rick B.
"ernst.schaefer@uni-oldenburg.de"
wrote in message
news:ernst.schaeferuni-oldenburg.de.4scllz@noreply.bbs.industrysoftware.automation.siemens.com...
> Hallo!
> install it again."
> knows any solution?
> Thanks in advance!
> ernst.schaefer@uni-oldenburg.de's Profile:
> http://bbs.industrysoftware.automation.siemens.com/vbulletin/member.php?userid=326132
> View this thread:
> http://bbs.industrysoftware.automation.siemens.com/vbulletin/showthread.php?t=45279
N/A
I have the exact same problem, UAC is turned off. I've looked in modules.txt and it have the 2 following errors:
Error: 7E could not load PLMIntegration.dll
Error: 7E could not load SSOService.dll
I Tried uninstalling many many times, no succes, logged in from another account with administration privilegues which my own account also have, no luck.
Any suggestions
