Revision Triangles
Hi Guys.
I am looking at suggesting using revision triangles to easily identify changes.
I cannot find where they are on the ribbon or even on search.
Any help is greatly received.
Betreff: Revision Triangles
Honored Contributor
Honored Contributor
Hi @Dazzie
You either will find the Dimension Tracker under the Tools tab, but I suppose this only will work with a 3D document behind but not in2D only mode
or You put those triangles Yourself onto the draft using the Balloon function under the Home tab
In this case take care that You have tunred off any leader line - suppose You will not have them
Wolfgang
Hi Phenom.
Thank you.
How will these work with manually inserted text?  I assume I may have to insert one manually
Honored Contributor
Honored Contributor
Hi @Dazzie
Yes, You have to put Your number manually into the balloon text where it is done autmatically by the Dimensions Tracker function.
But this Dimension Tracker only can track dimensions coming from a 3D file
Wolfgang
Hi.
Had a look at the dimension tracker and its not what I am looking for.
All I need is, when I rev up to a new revision I want that revision only to show where the changes are.
I think I will have to look into creating a block to do this for me.  Help will be greatly appreciated.
Honored Contributor
Honored Contributor
Hi @Dazzie
so in that case it might be the easiest way to use the ballon feature for creating triangle balloons to show wheer Your revisions are.
Wolfgang
