Rotate command
N/A
Using the rotate command also makes a copy at the same time. Can you tell what I am doing wrong?
Re: Rotate command
N/A
There is a button in the rotate command for copy.
If this button is down you get a copy.
If this button is up, you get move only.
Rick B.
Re: Rotate command
N/A
I see how it works now.
Thanks Ricky
Jim
