ST4 executable for XP?
Could anyone tell me where I can still get ST4 as I am still running XP?
Conrad
Re: ST4 executable for XP?
Hello Conrad,
do you have webkey account? if yes you can easily download it in PLM download server to get it.
Community Manager
Conrad,
Copy and paste the following link into the field at the top of your browser.
Press Enter and it should start the download.
You can actually just click on the link.
When you are prompted to Save or Run, I suggest you Save the download to a specific folder.
This way you have the download in the event that you have to install again at a later time. You will be prompted again to Run once the download is complete.
http://free2ddl.ugs.com/pub/SE2DDraftV104ENGLISH.exe
Rick B.
Esteemed Contributor
Ricky, I was hoping you would answer this.  I knew you had the answer Smiley Very Happy
Production: ST9 MP10
Testing: ST10 MP3
Hi Rick,
Thank-you for the quick response.
However, I get an "Access denied (policy denied)" message however I try this.
I believe a February post listed the same link, with the same result, so I assumed that ST4 was dropped from access with the issue of ST6.
Conrad
Bonjour,
Je recherche également ST4 FRANCAIS pour windows XP
Merci de votre aide
Christian39
