ST6 2D Download eng. or ger
Hello there,
i have a qick question. Since the Licence File of ST2 is no longer available, im currently upgrading our systems to ST7.
However not all of them are running on 64bit, so i need the Version ST6 too.
Can someone help me with a downloadling for it? I only found a link for a spanish Version.
Thank you very much. Any help would be appreciated
Re: ST6 2D Download eng. or ger
Esteemed Contributor
Hi there,
Just be aware that the files created [or last saved] in ST7 cannot be opened in ST6....either go for all ST6 installs, or update the systems to 64bit.
As to the link...you might try to edit the link to say ENGLISH instead of SPANISH, it might work if there is a file at that address.
Hi there,
thanks for the Info SeanCresswell.
I got a mail from Ricky Black with all necessary files and links. Now i will update our systems to ST6 and we should be fine for a while. There is a little problem with the mm and inch conversion but i have to take a deeper look at that first.
Anyway thanks for the good support and have a nice day.
