ST7 Alignment lines
Whe I upgraded to ST7 I lost my alignment lines. Changed the settings but still can not get them. I use these all the time. Unfortunately once you save a ST7 file you can not go back to a ST6 system. Need some help.
Bill
Re: ST7 Alignment lines
Community Manager
In 2D Drafting the toggle is  in Tools->Assistants command group.
The location of commands change from Draft to 2D Drafting.
Rick B.
That worked what does the Extensions setting do in the intelliSketch Relationship window do?
Bill
Community Manager
This allows you to create constraints such as 'connect' to an extension of an object. For example create a line that is connected to an existing line beyond the endpoint of the existing line.
Enable this option. Draw a line at an angle. Escape out of the Line command and start it again or just RMB to restart. Put the cursor on the line without clicking on it. Then move the cursor along the line and past one endpoint. Notice that you still get the indicator that the new line will be connected to the existing line. Click to start the new line. then click somewhere fot the other end of the  new line. The new line will be connected to the projection of the original line. If you modify the original line, the new line will also change accordingly.
Rick B.
Esteemed Contributor
bill_a wrote:
Bill
Hello Bill,
Extensions is particularly useful when trying to dimension the inferred point beyond where a fillet has already been applied.
