Reply
Save As Image
How can I save as image and get it to not scale the image down?
Re: Save As Image
In the options dialog for Save as Image you should be able to set the size
the same as your sheet size.
Rick B.
Re: Save As Image
Which in itself creates another problem since the "Save as Image" option is nothing more than a glorified screen shot. It's bounded to what I see in the window rather than what's on the worksheet. So If I'm zoomed in on a portion of the work area, the save as image is of that area only.
