Scroll Bars
N/A
Hi!
I'm trying out solidedge and I noticed that mousewheel zoom becomes
actives when you remove the scroll bars (options/view).
Is there a way to make this setting persistent?
Sorry if this been addressed before.
V.19.00.00.66 (Is there a newer one?)
-Marc
Re: Scroll Bars
N/A
Ok I found it, I have to set the option in the template file. Smiley Happy
I had yet another question: is there a way to save keyboard shortcuts
for a later installation?
Marc
Marc Tellier wrote:
> Hi!
> Regards,
> -Marc
Re: Scroll Bars
N/A
Marc,
Right mouse click in the toolbar area at the top of the application.
Click on the Customize command in the menu.
Click on the Keyboard tab in the Customize dialog.
You can customize the application here.
Rick B.
Re: Scroll Bars
N/A
Hi Ricky,
Thanks for the reply, I was actually wondering if a way to *save
*customizations (after you have assigned them) existed.
Maybe a file contain this information?
I am quite impressed by this software and I am glad to have taken some
time to try it.
I previously used autocad quite a lot and also solidworks to some extents.
I am confused a bit with paper and 2d sheets but I imagine I will sort
this out eventually.
Marc
Ricky Black wrote:
> Marc,
> Regards,
> Rick B.
Re: Scroll Bars
N/A
Marc,
Whatever you customize becomes a user preference and is not file specific. If you close the application and run again the customization should be remembered.
Rick B
