Setting Dimension projection lines
How can you set up SolidEdge 2D dimensioning so the projection lines always start away from the drawing?
I can go to Properties on each dimension after they have been placed and set the Element Gap but is there a way of setting this gap up so it does this automatically?
Re: Setting Dimension projection lines
you should modify the Dim style...   not just the individual dimension
Matt Johnson
Teamcenter 10.1.6
Matt,
Thanks for your reply!
But how?
I have tried everything I can think of!
Use command finder to find "Styles"  in Styles pick "Dimension"   then the Dim Style you are using...  make the change here and then when you place a new dim it will honor that setting as part of the dim style.
see short demo video: https://www.screencast.com/t/gw32JNSxR3YP
See these  two help links below.
https://docs.plm.automation.siemens.com/data_services/resources/se/109/se_help/en_US/selfPacedExt/xi...
https://docs.plm.automation.siemens.com/tdoc/se/109/se_help#uid:index_styles:xid377899
Matt Johnson
Teamcenter 10.1.6
Thank you!
Done it and it works!
That is hidden deep down for someone like me!!!
glad you got it. I see my mouse did not come thru on the recording... HTH
Matt Johnson
Teamcenter 10.1.6
