Solid Edge tutorial
N/A
Could you send me the Solid Edge 2D Drafting 19 tutorial web address ?
thanks
Best regards
Re: Solid Edge tutorial
N/A
The tutorials are delivered with the software. What problem are you seeing
when you try to run the tutorials?
Rick B.
N/A
>Regards,
>Rick B.
>It is OK. But the solid edge 2D tutorial is about right line and I want to draw
pieces for woodturning. For example : the attached file.
- Using functions :
- Arc
- Cercle
- Courbe
- Congé
- chanfrein
A. Giboire
