V100 - MORE THINGS I DON'T LIKE
N/A
I don't like it when I move/copy a group and the new group is no longer a group.
I don't like it that the Previous View don't work when using the left key to change
views. THe Previous View is important and it should have longer memory than just
the last view.
I don't like it when I select an object and press DELETE an nothing happens.
I don't like it when I want to copy an object when I MOVE it by pressing Ctrl and
the coping don't work. I have to open the MOVE bar and press the Copy icon.
I don't like it when I want a Grouped object to align with line by using the Colinear
command and instead of the entire Group moving, just the line in the Group that
I choose, moves.
I don't like when I move an object and want to place it at one of snap points (e.g.,
C = Center) and nothing happens.
Enought for now.
Ron
Ronald W Latour
Re: V100 - MORE THINGS I DON'T LIKE
N/A
See my replies below
"Ronald W Latour" wrote in message
news:490f542a$1@bbsnotes.ugs.com...
> group.
I don't see this behavior. Make certain you have the Top Down button
active in your Select menu.
See attached GROUP image
> to change
> than just
> the last view.
Then it wouldn't be the Previous View. If you want to go back to the
same view
regularly look at Named Views
> happens.
You'll have to be more specific. I can delete things without problem
> Ctrl and
> icon.
To use the Ctrl key don't activate the Move command. Just selet the
object(s),
hold down Ctrl, then drag. When you hold Ctrl you should see a plus
sign appear
> the Colinear
> that
> I choose, moves.
Don't know how you're using Groups but you may want to look into Blocks
> points (e.g.,
You must have the hover over the target object such that it is
highlighted before
hitting "C". Don't need to select it just have it highlighted
> Enought for now.
> Ron
> Ronald W Latour
