Reply
cannot open dxf or dwg files
When i save a file as either DWG or DXF I cannot open the file. I was having this
problem at home so I installed it on my work PC and I am having the same issue.
Re: cannot open dxf or dwg files
Jeff,
What program are you using to try to open the DWG or DXF files?
Ed
>this
Jeff,
Have you tried a simple file? Draw a single line and translate. Can you open
the file in AutoCAD?
Rick B.
