cant install SE2Ddraft.exe
N/A
Since my systemroot is not C:\ Solid Edge seems to have a problem to be installed
in another drive.
It unpacks correctly but when i hit the unpacked setup.exe to install the software
it pops up with an error invalid drive c:\ .
Is there any possibility to install the software in another systemroot ?
Re: cant install SE2Ddraft.exe
N/A
Sebastian,
There is a post further down titled 'Solid Shield won't install on J:
drive'. It will offer some suggestions. One is to plug in a USB flash drive.
The system should name it C:\. Leave it plugged in while you install the
software. Everything should install properly.
Rick B.
N/A
Many thanks for the quick help.
The posted solution worked fine.
