Reply
copy command
I don´t like the offset-command.
Is there a simple copy-command (marking elements and inputting vector) anywhere?
thanks
Hermann
Re: copy command
Hermann,
I am assuming by copy you mean copy/paste. Is that correct. This puts the
geometry on top of the original. Use the Move command with the copy option
enabled instead.
Rick B.
