Reply
is SE free 2D licensing - node dependant
If I download and register, and get an SElicense.dat file, is it
tied to the node I downloaded from? It doesn't appear to be as it
has HOSTID=DEMO. Just wondered if each installed node needs to be
registred.
Re: is SE free 2D licensing - node dependant
Tony,
No the software is not node locked. If you want to test the software on multiple
machines, all you need to do is to copy the executable you downloaded to the multiple
machines and install the software. After you install the software, use the same
procedure as before to put the license in for each machine.
Rick B.
