license issue
N/A
I Downloaded a Solid edge v19.
I also received an email with the license attached with it
Can I use that license to install solid edge to more than one station?
Is there a time limit when using the license?
(Yes I have license problem right now)
thanks
Re: license issue
N/A
Yes, within your own company you can install it on as many seats as you
like. We'd ask though that if another company wants to use it, that they too
register and get their own license file.
You are authorized to use the software indefinitely, but you must return to
the license site each year to get a new license to enable this and answer a
few questions regarding your usage.
Re: license issue
N/A
>a
I just registered 3 users for 3 licenses for our company
I just can't use the license for their station, it won't work
message is "invalid license, contact your administrator)
fabien
Re: license issue
N/A
Fabien,
You only have to register once. A single license may be used on all your
machines.
Please check and answer the following:
1. What operating system are you running? XP Pro or Vista.
2. Did you receive an email with the license attached and directions for how
to apply the license?
3. Did you put the license file in the proper folder? Where did you put the
license file?
4. Open the SELicense.dat file with Notepad, not Word. There is a date in
the text in the file. Is the date October 2008? Do not modify or save the
file, just exit. Changing the file will invalidate it.
Rick B.
Re: license issue
N/A
1-xp pro sp2 french
(the license worked on my PC only)
2- yes
3-yes (C:\Program Files\Solid Edge 2D Drafting V19\Program)
4- date is 31-octobre-2008
"Ricky Black" wrote:
>Fabien,
>machines.
>license file?
>Regards,
>Rick B.
