print grid to drawing
N/A
I,m new to SE FREE2D.
I,m drawing my yard so I can to install an underground irrigation system. I need to print out the grid and the drawing together, so I can send it in to a free design service.
I have the grid over my drawing at 10 ft. major and 1 ft. minor dim., but for the last week, I can't seem to figure out how to print it together and any help would be appreciated.
Sid
Re: print grid to drawing
N/A
Sid,
The grid is used for geometry creation and deliberately does not print.
Place lines that represent your grid layout on a separate layer.
Then you can simply turn on/off the display of that layer.
Rick B.
N/A
Rick
I have a similar question to Sid in that I want to place lines to represent a suspended ceiling grid. I set the grid to 600mm with snap to and placed each line in individually - OK for a small room, but is there an automated way to do this?
Matthew
N/A
No, you have to create multiple lines at the specified distance.
Rick B.
