spline curve editing
N/A
I am trying to draw a curve "close" to the final shape, and then go back in and edit
the point locations to a precise point in the properties dialog, where the location
of each point is listed, but is not editable. A similar trick works with a series
of lines, so is there an analog for editing curves?
Doug Griggs
p.s.
I think this question relates to an earlier one about "curves by table", for which
the answer was "not supported in free 2d".
Re: spline curve editing
N/A
Doug,
Since splines can be "driven" by dimensions (make sure Maintain
Relationships is on), use dimensions to the vertex points to place them
where they need to be.
PellaKen
http://grundey.blogspot.com
"Doug Griggs" wrote in message
news:478f96da$1@bbsnotes.ugs.com...
> in and edit
> location
> a series
> Thanks,
> Doug Griggs
> p.s.
> for which
