Reply
Solved! Go to solution
where do I find the properties
so I can switch from mm to inches . Thanks
Solution
Solution
Accepted by topic author jamie
‎08-26-2015 04:32 AM
Re: where do I find the properties
nevermind , I guess they want you to reinstall the product and choose ANSI when prompted during the re-installation ??
Jamie,
Improvements are being made in ST7 to easily change the units after installation.
Rick B.
You could also download and run this PowerShell utility to quickly change your template standard without uninstalling and reinstalling.
