Reply
Installation failed
“Error 1330: A file that is required file cannot be installed because the cabinet file …..\....\LightW~.cab has a invalid digital signature. ….. Error 3 was returned by WinVerifyTrust.” After checking temporary directory where was this CAB-file I found that LightW~.cab is digitally UNSIGNED . Why others CAB-files are signed and this not? It’s possible to get new installation file where LightW~.cab is signed or there are other solution for this problem?
Computer: mobile workstation HP NW9440, 4GB RAM, Windows XP Professional 32bit
Re: Installation failed
This is typically due to a corrupted file during download, i've sent links to re-download.
Please try again and let me know if you have any issues.
Kris Kasprzak
SOLVED: WinXP reinstall
I have error 1311 sourse file not found 'ADDINS.cab' can anyone help?
time to go back to inventor
I had the same "Error 1330: A file that is required file cannot be installed because the cabinet file &..\....\LightW~.cab has a invalid digital signature. &.. Error 3 was returned by WinVerifyTrust." I disabled the antivirus during the installation (in my case, Avira Free) and everything went ok.
I hope it works for you
