3D-Pdf with API / ST4
Hello
How can I create 3D-Pdf with ST4 (in Batch with vb.net)?
When I try with objdoc.saveas(filename.pdf), it have only a 2D-Pdf.
Any help.
Heinz
Posted by: Heinz Rindlisbacher
Post date: 9/12/2011 1:29:14 AM
RE: 3D-Pdf with API / ST4
I have found a solution
objdoc.saveas(filename.pdf,,true) works!
important: 2 x ,
Heinz
Post date: 9/12/2011 3:55:34 AM
